Brief Description: Installing the Surfaces to the Main Shaft
Took the plane out of the workshop installed the wings / elevator and put it on the stands to set it up in level. Thereafter we measured the distance from elevator tip to wing tip left and right with a nylon line. We corrected slightly here and slightly there until the distance was plus minus 1 mm. Since drilling was not possible in the installed condition we had to mark the support plates really well before taking them off.
